My device has an issue with IC9, can I purchase a similar one available on eBay for replacement? Seeking advice. Thank you!
[HELP] Replace IC9 8355 Input/Output in Beocord 8004.
It's mask programmed by/for B&O.
But these rarely fail.
What are the symptoms?
When pressing play, the motor does not engage, and the heads do not lift up.
Does the display light up ?
